Bugs in active presenter. We can only tick up to three checkboxes. If more than that it will not be ticked.
ActivePresenter version: 8.5.5
OS: Windows 10
Notes: Bugs in checkbox
OS: Windows 10
The problem is found. Apparently, In Active presenter, I does not allow us to check the box after the slide ended. So the solution is to extend the time line.
I just want to add further information. In some cases, you may want to turn off the Transition > Auto Advance option of slide instead of extending the duration of the slide.
