I want to set the value of a boolean variable through Javascript. I tried various options, like
prez.variable(‘gef_Obj_SchlüsselGrün’, “true”);
In my Project %gef_Obj_SchlüsselGrün% shows me the correct value. But the variable does not really seem to be set to ‘true’. For example if I want to show an object on the condition
if gef_Obj_SchlüsselGrün is equal to True
The object does not show, even though in the slide %gef_Obj_SchlüsselGrün% gives me the value ‘true’.
What am I missing?
Thanks,
Rolf
I would like to suggest that a comment to that effect is added to the manual on page 260 where it says about setting variables
“Value of variable, can be a string or number.”
