Is there a way to blur out a portion of a simulated recording screen? I know you can do it with a video but I can’t figure out how to do it on a Software simulation.
ActivePresenter Version:
Version 7.5.9
OS:
Windows 10
Version 7.5.9
OS:
Windows 10
Hi Nix,
When you use Record Software Simulation, the image was captured as slide background.
To blur information on an image, you can access to the built-in image editor to do that by right-clicking on the Background canvas and selecting Edit Background Image.
Inside the Image Editor, there is a Blur tool. You’ll have to blur each slide image separately.
Awesome! thanks you!
