I need to know the settings and preparations that can produce the best quality of a software simulation to be posted on social media as quick tutorials.
Here are our instructions on how to have the best recording quality:
There are two things that you need to prepare: recording settings and exporting video settings. However, first of all, you have to determine which type of recording you are going with. It would be best for you to go with recording software simulation if the app that you want to record has no animation. Otherwise, choose recording video.
Video codec: Flash Screen Video. The video file size will be large so you should consider it yourself.
If you want to upload the video output on social media, I suggest you export it to an mp4 format.
Hang
