Hi all, I just started working wuith AP. My first project works fine in the HTML5-preview. When I export it, the buttons to navigate the slides don’t work, I am stuck at slide 1. What is my mistake?
You can customize the Navigation option in the Player Settings dialog. Open the Export tab > Player Settings > General tab > select the Operation Mode you want to customize > Content section > Navigation.
By default, the Free option is selected in Demo, Practice and Tutorial modes. it allows you freely to move backward or forward. Meanwhile, for the Test mode, the Backward Only option is selected, it means that you cannot navigate to the next slide.
Quynh
