Hi! Is there a possibility to remove the backgroung noise from the created videos? The voice of the speaker is loud enough but there is a bit “hubhub” and would like to take that off.
The current version of ActivePresenter doesn’t support this feature. You will need a third-party tool (such as Audacity at http://www.audacityteam.org/home/) and follow below steps to do that:
- Right-click the audio object and select Export To File
- Select WAV format to preserve the quality.
- Use Audacity to remove noise from the audio.
- Import the edited audio back to ActivePresenter.
