Hello there,
I’m recording my screen but my labtop fan sound disturbing the listeners, I tried to remove/decrease but the option ‘background noise reduction’ is disabled.
could someone help me how enable that?
thanks.
This function is used for the audio file only, not the video file. You can separate audio from video, then reduce noise for the audio file. Although ActivePresenter doesn’t support detach audio from video directly, you still can do that with a few steps as in the following video:
Please choose audio source from your computer to enable the audio noise reduction function.
