When using background music, it’s set to loop forever. However, if I select a range of the background music and lower that range’s volume (for example, there is a video play on the same page so I want the background music to be minimum), it can be seen that later in the timeline, the same range in the repeated background music got lower volume as well.
Specific example:
when I edit slide 1, and set 5-10 seconds of background music to low volume. then at slide 6, when the background music repeats, its 5-10 second range also got lower volume, which will appear to the user as background music is broken because there is no video being played at slide 6 and no need to lower background music’s volume.
ActivePresenter version:
8.2.1
OS:
windows
Thanks!
