Hello! I have the same background image for all of my slides, and when moving from one slide to the next, the background image takes a half second to load, giving the module an unfinished feel. Is there a way to further embed the image into the slide to make the transition seamless? I am on Active Presenter 9, using a Windows 10 machine. Thanks in advance! --Michaela
It seem that the image used for background image is quite large, so it make the slides in your project transform unsmoothly.
In this case, you can try reducing the image size to get better feel.
Just take a look at this tutorial video to get detail information:
Since you used the same background image for all your slides, you can try doing this way: Right-click the image at the first slide > Show over Multiple Slides > Bottom Layer.
Hope that it helps.
Kind regards,
