The Entrance and Exit animations are automatically added to every object. What is the intention of doing so? And is there a way by which this can be stopped?
If you don’t set playhead at any position, no animation added when inserting an object. That means the object will show from the start to the end of slide.
ActivePresenter adds the Appear and Disappear effects to a object if it shows or hides at a specific time stamp and treat them as special types of effects. By that way, you can change the animation types without affecting the start time and duration of the object.
