Hello there,
I know how to set the audio to play continuously in multiple slides, but can you tell me how to set the same audio to play continuously in the green slide, except for the red slide。
You can consider doing this way as a workaround.
Step 1: Insert 2 audio tracks in slide 1.
Step 2: Right-click one audio track (the 2nd audio) > Play over Multiple Slides.
Step 3: Adjust the start time of the 2nd audio above so that it starts playing in slide 3.
