Audio resource metadata (like Author, Album etc.)
Hi, is there any possibility to use audio file metadate inside APPROJ?
Typical use for me should be author (speaker). I mean: Same name of the audio resource, but another speaker. Possibilty to look into resource list and see this resource property (= “audio is spoken by: …”)
I am using .flac files - so if there is a way to utilize its existing metadata when importing.
Thanks, Tomas
Long time no see, Tomas. Hope that you’re doing well.
From your description, I understand that you want to identify the author or speaker of the audio resource.
If so, it is possible to do that in ActivePresenter. Here’s how:
  1. Import your audio files into ActivePresenter.
  2. Navigate to the Resources pane > right-click the audio file that you want to customize its name > Properties.
  3. Enter more information into the Name section of the pop-up dialog > OK.
    By doing so, you will be able to associate the speaker’s name with the corresponding audio resource and easily identify and track the different speakers within your project.
Hope that it addresses your concern.
Best regards,
