I’d like a ticking timer to loop continuously on a slide. However would also like the sound to fade in.
When i fade in with looping, it loops the fade in. Ideal behaviour would be fade in happens once, then audio loops.
Is there any way to achieve this?
Unfortunately, the current version of ActivePresenter hasn’t supported this feature yet.
We will try to improve it in the future.
However, you can adjust your audio manually to restore its original volume.
Please take a look at this tutorial to get detailed information:
In addition, you can consider doing this way as a workaround:
Insert two same audio consecutively. Then, using fade in for the first audio and loop for the second one.
Best regards,
