Hello,
audio inserted in a group that is initially not visible cannot be heard.
Is it possible to call it back via javascript?
Thanks!
It seems that you have set both the group and the audio object to Initially Hidden. To achieve what you want, right-click the audio object and uncheck Initially Hidden.
Thank you very much Hang Nguyen, I will try!
