Does Animate have the capacity to include audio tracks on the timeline, with limited ability to move and edit those tracks (fade in/out, copy/paste segments etc)?
Hi Peter,
You can use media volume animation for audio fade in/out effect, and playback animation (play media from) so that it plays as if you copied/pasted its segments. However, on mobile devices, media volume animation doesn’t work, and playback animation must be initiated by the user action (e.g tap).
So you should edit the audio in ActivePresenter then import it into Saola Animate.
Regards.
