Why is the result of the percentage %apQuizScorePercentage not correct? For example the total questions is 17 and there are 11 correct, it gives a grade of 41% - should be 64.7%. I gave each question 1 point each.
There are multiple questions per slide.
It would be helpful if you can share the project having the issue and its external data folder named in the PROJECT_FILE_files (if any) to support@atomisystems.com so that we can check.
If these files are large, you can upload them to a cloud storage site like Google Drive then send the download link to us.
Hi I don’t really know what happened but I just shrunk all unused resources before saving and when I run again, it was giving me the right answer.
Thanks so much for the prompt reply
