Problem: How do I use a theme in a Project (Project 1) and apply it in another existing Project (Project 2)? I have saved Project 1 as a .aptheme file type. Now how do I import it into Project 2?
ActivePresenter Version: 7.
OS: Required. Windows
In case you have saved Project 1 as a .aptheme, so it will appear in Custom section of the theme gallery in the Design tab.
Now, to apply this theme into Project 2, just open the Design tab and click its thumbnail.
Please take a look at this tutorial to know how to work well with themes in ActivePresenter.
Best regards,
Thank you Thuy! This helps.
