I just downloaded AP 8.
I converted a project from AP7 to 8. Now I have uploaded it for testing. I have asked some friends to check it.
Android phones seem to work fine. But in a Iphone XS and Iphone 8 de buttons seem to disappear or they are colorless?
On Iphone 7 it does seem to work.
Can you please send the project to support@atomisystems.com so that we can check.
You can keep only one slide that has this issue and delete the others.
I would like to address another (separate) issue.I removed all the slides from the project and saved it again (also in the pools I have created). But the size of the project does not decrease. I have also noticed this in the past for AP7
see image
I’ve requested to access your file, please accept.
I forgot to mention that to decrease the file size, you must select ActivePresenter menu > Project > Shrink: Delete All Unused Resources and Shrink.
