Any advice on setting Unicode character feature?
Sequence of characters changed in input of text field in text caption for a Unicode-compliant word written on Notepad and on this web page - that appear correct.
For testing - compare the two appearances - can copy this word - " ကောင်း " and paste it in text field of text caption and on Notepad.
I use Windows 8.1
Thanks
Hi Wang,
Can you please let us know which is the version of ActivePresenter you are using? Windows or Mac?
Version is 6.1.0 released 2017.04.11 on Windows 8.1
Ta
Your provided text " ကောင်း " shows correctly in our tests. Do you use any special font? We are sorry that we have no experience in Burmese language.
No, Windows 8.1 has built-in Burmese font. Well, that’s a good one.
I don’t know what happen in my computer. Problem solved now.
Thanks
