I have created a quiz using question pools but need the countdown timer to display on the random question slides.
Hi Kevin,
You should go to each slide in slide pools then adding an animated timer.
In addition, you can make an animated timer shows over multiple slides by select “Show over Multiple Slides” in the context menu.
