Amazon polly TTS don’t work
ActivePresenter version: 8.1.1
OS: win 8.1
- amazon polly test is OK
2.
but don’t work here.
OS: win 8.1
2.
We couldn’t reproduce the problem in our test. What is Amazon Region that you use?
Could you please test to generate the voice in Amazon Polly console site?
https://us-east-2.console.aws.amazon.com/polly/home/SynthesizeSpeech
I changed the display language to English en_US, and it worked fine. Is it possible that the display language to Chinese zh_CN will be wrong and irregular?
It should work properly in any display language. It looks like a bug or an issue.
Could you please send us a sample project that you created in the Chinese display language and the log file of ActivePresenter?
log:
2020-08-03 12:29:29: ValidationException
2020-08-03 12:29:29: {“message”:“3 validation errors detected: Value null at ‘voiceId’ failed to satisfy constraint: Member must not be null; Value null at ‘text’ failed to satisfy constraint: Member must not be null; Value null at ‘outputFormat’ failed to satisfy constraint: Member must not be null”}
https://open.youtu.qq.com/#/open/developer/voice
Suggestion: It would be nice to add the above TTS, especially for Chinese phonetic support.
Could you give some additional information: Your OS version and Display language of your OS?
2020-08-03 12:23:36: ActivePresenter 8.1.1 - 64-bit build. (Release Build: 2020.07.24) started
OS: Windows 8.1 (build 9600), 64-bit edition
CPU Count: 4
Hostname: home-pc. Memory: 8,099 MB. Available: 4,986 MB. Memory Load: 38%
Disk Space: 76,722 MB (Free: 14,752 MB)
Project Location: C:\Users\cyj\Documents\ActivePresenter
2020-08-03 12:23:36: TempDir: C:\Users\cyj\AppData\Roaming\ActivePresenter\temp
2020-08-03 12:23:36: Direct3D rendering mode: hardware
2020-08-03 12:23:40: Direct3D device type: 1
2020-08-03 12:23:44: Opening project: C:\Users\cyj\Desktop\未命名.approj
2020-08-03 12:23:45: PrepareRibbonBar: 479ms
2020-08-03 12:23:46: RLMedia: Using AVStream.codec to pass codec parameters to muxers is deprecated, use AVStream.codecpar instead.
2020-08-03 12:23:46: Audio Decoding Stats: Process 2.000000, Wait 1.000000
2020-08-03 12:23:46: Audio Encoding Stats: Process 0.000000, Wait 3.000000
2020-08-03 12:23:59: TempDir: C:\Users\cyj\AppData\Roaming\ActivePresenter\temp
2020-08-03 12:24:04: RLMedia: Estimating duration from bitrate, this may be inaccurate
2020-08-03 12:24:04: Preparing to play audio to: . Channel: 1. Sample rate: 22050. Sample Format: 2147483656
2020-08-03 12:24:04: Could not open audio output stream to play: Invalid device.
2020-08-03 12:24:04: Preparing to play audio to: . Channel: 2. Sample rate: 48000. Sample Format: 8
2020-08-03 12:24:04: Audio frames decoding started.
2020-08-03 12:24:09: RLMedia: Estimating duration from bitrate, this may be inaccurate
2020-08-03 12:24:09: RLMedia: Using AVStream.codec to pass codec parameters to muxers is deprecated, use AVStream.codecpar instead.
2020-08-03 12:24:09: Audio Decoding Stats: Process 2.000000, Wait 0.000000
2020-08-03 12:24:09: Audio Encoding Stats: Process 2.000000, Wait 1.000000
2020-08-03 12:24:09: Audio Decoding Stats: Process 3.000000, Wait 0.000000
2020-08-03 12:24:09: Audio Encoding Stats: Process 1.000000, Wait 2.000000
2020-08-03 12:24:23: RLMedia: Estimating duration from bitrate, this may be inaccurate
2020-08-03 12:24:23: Preparing to play audio to: . Channel: 2. Sample rate: 48000. Sample Format: 8
2020-08-03 12:24:23: Audio frames decoding started.
2020-08-03 12:26:09: {“message”:“3 validation errors detected: Value null at ‘voiceId’ failed to satisfy constraint: Member must not be null; Value null at ‘text’ failed to satisfy constraint: Member must not be null; Value null at ‘outputFormat’ failed to satisfy constraint: Member must not be null”}
2020-08-03 12:26:29: RLMedia: Estimating duration from bitrate, this may be inaccurate
2020-08-03 12:26:29: Preparing to play audio to: . Channel: 2. Sample rate: 48000. Sample Format: 8
2020-08-03 12:26:30: Audio frames decoding started.
2020-08-03 12:30:31: ActivePresenter 8.1.1 (Release Build: 2020.07.24) shut down
Could you please help us check the problem with this temporary version?
This bug has been fixed。
Thank you for your support. It will be fixed in the next release.
Regarding the integration of Tencent TTS voices, we will support if get more requests from users.
