Problem: Hello, is there any way to reuse the advanced actions between different pages of a project?
Thanks!!
ActivePresenter Version: 8.
OS: Windows.
Thanks!!
OS: Windows.
Advanced Actions are meant for reusing, that’s why you must name them when creating.
You should take a look at below article:
Thanks for your answer. Excuse me, I was referring to using them in different projects, not in pages of the same project.
Thank you!!
Unfortunately, at the current version, reusing advanced actions in different projects is not supported.
We will try to implement it in the future release.
In this regard, it would be awesome to save advanced action in events with object templates.
Have a nice day.
