Advanced Actions Menu cannot be resized
Advanced Actions Menu cannot be resized.
ActivePresenter version: 10
OS: Windows 11
Thanks for looking into this.
Hi Koen,
Kindly attach a screenshot illustrating your issue so we can understand it better.
BR,
When you open the Advance Actions menu, it doesn’t matter which side of the window you grab, it won’t resize.
Very inconvenient when working on small laptops.
OK, I was wrong here. The issue is a little different than I thought. The window does resize, but it doesn’t allow you to shrink it very much. The minimum width of the window is very large.
