Is there anyway to reuse advanced actions across projects?
We can copy/paste objects across projects and that copies all their properties except advanced actions.
Does saving object as template saves its associated advanced actions also?
thanks
The current version of ActivePresenter hasn’t supported reusing Advanced Actions across projects.
You have to create Advanced Actions manually.
We’ll consider implementing this feature if there are more requests from users.
Best regards,
Oh! alright.
I guess then saving an object as template with associated advanced actions is also not supported when reused?
Please add this a feature request.
Thanks for your suggestions.
Advanced Actions just can be created and reused in the same project.
Kind regards,
