My game keeps lagging whenever I try to record using ActivePresenter, and I don’t want to post a vid with lag because nobody wants to watch that.
Please tell me how I can reduce lag.
Thanks.
Thanks.
Hi Frederic,
Please try using H264 codec in Recording Settings, and selecting Use Direct3D option.
Thanks, I appreciate you replying, I will definitely try that immediately. Thank you again.
Hello again, when I went to ActivePresenter and tried to use that setting it wouldn’t show the option Direct3D. Maybe it’s because i’m on a MacOS? please tell me how to get that feature
Hi Frederic,
Yes, the Direct3D option is not available on macOS.
There’s only H264 codec option that you can try.
