Problem: I’m using ActiverPresenter on my MacBook Pro. When I open the program I get the error message: “Cannot get the official hostname (error 0: Undefined error: 0)”. But then I can use the program to build my slides.
When I start recording audio then the program crashes all the time at random points. Some recordings work, but most of the time it crashes after a couple of seconds. I do not get an error message then.
ActivePresenter Version: 7.3.3
OS: macOS Mojave (10.14) and also on macOS High Sierra (10.13)
Notes: This is part of the log I have (could not add all because of character limit):
2018-10-27 17:24:57: Error: Cannot get the official hostname (error 0: Undefined error: 0)
2018-10-27 17:24:57: ActivePresenter 7.3.3 (Release Build: 2018.09.06) started
OS: OS X Version 10.13.6 (Build 17G65). Version: 10.13 - 64 bit
CPU Count: 4
Hostname: . Memory: 16,383 MB. Available: 12,764 MB
Project Location: /Users/imcovangent/Documents/ActivePresenter/
Disk Space: 239,172 MB (Free: 9,847 MB)
2018-10-27 17:24:57: TempDir: /Users/imcovangent/Library/Application Support/ActivePresenter/temp
2018-10-27 17:26:53: RLMedia: Using AVStream.codec to pass codec parameters to muxers is deprecated, use AVStream.codecpar instead.
2018-10-27 17:26:53: Preparing to play audio to: Built-in Output. Channel: 2. Sample rate: 44100. Sample Format: 8
2018-10-27 17:26:53: Preparing to record audio from: Built-in Microph. Channel: 2. Sample rate: 44100. Sample Format: 8
2018-10-27 17:26:55: RLMedia: Using AVStream.codec to pass codec parameters to muxers is deprecated, use AVStream.codecpar instead.
2018-10-27 17:26:55: Audio Decode Stats: Process 3.000000, Wait 0.000000
2018-10-27 17:26:55: Audio Encoding Stats: Process 2.000000, Wait 4.000000
2018-10-27 17:27:12: RLMedia: Using AVStream.codec to pass codec parameters to muxers is deprecated, use AVStream.codecpar instead.
2018-10-27 17:27:12: Preparing to play audio to: Built-in Output. Channel: 2. Sample rate: 44100. Sample Format: 8
2018-10-27 17:27:12: Preparing to record audio from: Built-in Microph. Channel: 2. Sample rate: 44100. Sample Format: 8
2018-10-27 17:27:43: Error: Cannot get the official hostname (error 0: Undefined error: 0)
2018-10-27 17:27:43: ActivePresenter 7.3.3 (Release Build: 2018.09.06) started
CPU Count: 4
Hostname: . Memory: 16,382 MB. Available: 8,330 MB
Disk Space: 239,172 MB (Free: 9,964 MB)
2018-10-27 17:27:43: TempDir: /Users/imcovangent/Library/Application Support/ActivePresenter/temp
2018-10-27 17:30:17: RLMedia: Using AVStream.codec to pass codec parameters to muxers is deprecated, use AVStream.codecpar instead.
2018-10-27 17:30:17: Preparing to play audio to: Built-in Output. Channel: 2. Sample rate: 44100. Sample Format: 8
2018-10-27 17:30:17: Preparing to record audio from: Built-in Microph. Channel: 2. Sample rate: 44100. Sample Format: 8
2018-10-27 17:30:38: RLMedia: Using AVStream.codec to pass codec parameters to muxers is deprecated, use AVStream.codecpar instead.
2018-10-27 17:30:39: Audio Decode Stats: Process 52.000000, Wait 0.000000
2018-10-27 17:30:39: Audio Encoding Stats: Process 14.000000, Wait 40.000000
2018-10-27 17:32:11: RLMedia: Using AVStream.codec to pass codec parameters to muxers is deprecated, use AVStream.codecpar instead.
2018-10-27 17:32:11: Preparing to play audio to: Built-in Output. Channel: 2. Sample rate: 44100. Sample Format: 8
2018-10-27 17:32:11: Preparing to record audio from: Built-in Microph. Channel: 2. Sample rate: 44100. Sample Format: 8
2018-10-27 17:32:31: RLMedia: Using AVStream.codec to pass codec parameters to muxers is deprecated, use AVStream.codecpar instead.
2018-10-27 17:32:31: Audio Decode Stats: Process 57.000000, Wait 0.000000
2018-10-27 17:32:31: Audio Encoding Stats: Process 24.000000, Wait 37.000000
2018-10-27 17:32:56: RLMedia: Using AVStream.codec to pass codec parameters to muxers is deprecated, use AVStream.codecpar instead.
2018-10-27 17:32:56: Preparing to play audio to: Built-in Output. Channel: 2. Sample rate: 44100. Sample Format: 8
2018-10-27 17:32:56: Preparing to record audio from: Built-in Microph. Channel: 2. Sample rate: 44100. Sample Format: 8
2018-10-27 17:33:01: RLMedia: Using AVStream.codec to pass codec parameters to muxers is deprecated, use AVStream.codecpar instead.
2018-10-27 17:33:01: Audio Decode Stats: Process 9.000000, Wait 0.000000
2018-10-27 17:33:01: Audio Encoding Stats: Process 3.000000, Wait 7.000000
2018-10-27 17:33:15: RLMedia: Using AVStream.codec to pass codec parameters to muxers is deprecated, use AVStream.codecpar instead.
2018-10-27 17:33:15: Preparing to play audio to: Built-in Output. Channel: 2. Sample rate: 44100. Sample Format: 8
2018-10-27 17:33:15: Preparing to record audio from: Built-in Microph. Channel: 2. Sample rate: 44100. Sample Format: 8
2018-10-27 17:33:40: RLMedia: Using AVStream.codec to pass codec parameters to muxers is deprecated, use AVStream.codecpar instead.
2018-10-27 17:33:40: Audio Decode Stats: Process 59.000000, Wait 0.000000
2018-10-27 17:33:40: Audio Encoding Stats: Process 30.000000, Wait 28.000000
2018-10-27 17:34:00: RLMedia: Using AVStream.codec to pass codec parameters to muxers is deprecated, use AVStream.codecpar instead.
2018-10-27 17:34:00: Preparing to play audio to: Built-in Output. Channel: 2. Sample rate: 44100. Sample Format: 8
2018-10-27 17:34:00: Preparing to record audio from: Built-in Microph. Channel: 2. Sample rate: 44100. Sample Format: 8
2018-10-27 17:34:29: RLMedia: Using AVStream.codec to pass codec parameters to muxers is deprecated, use AVStream.codecpar instead.
2018-10-27 17:34:29: Audio Decode Stats: Process 80.000000, Wait 0.000000
2018-10-27 17:34:29: Audio Encoding Stats: Process 38.000000, Wait 43.000000
2018-10-27 17:34:34: Preparing to play audio to: Built-in Output. Channel: 2. Sample rate: 44100. Sample Format: 8
2018-10-27 17:35:09: Preparing to play audio to: Built-in Output. Channel: 2. Sample rate: 44100. Sample Format: 8
2018-10-27 17:35:41: RLMedia: Using AVStream.codec to pass codec parameters to muxers is deprecated, use AVStream.codecpar instead.
2018-10-27 17:35:41: Preparing to play audio to: Built-in Output. Channel: 2. Sample rate: 44100. Sample Format: 8
2018-10-27 17:35:41: Preparing to record audio from: Built-in Microph. Channel: 2. Sample rate: 44100. Sample Format: 8
2018-10-27 17:35:55: RLMedia: Using AVStream.codec to pass codec parameters to muxers is deprecated, use AVStream.codecpar instead.
2018-10-27 17:35:55: Audio Decode Stats: Process 32.000000, Wait 0.000000
2018-10-27 17:35:55: Audio Encoding Stats: Process 17.000000, Wait 15.000000
2018-10-27 17:36:04: RLMedia: Using AVStream.codec to pass codec parameters to muxers is deprecated, use AVStream.codecpar instead.
2018-10-27 17:36:04: Preparing to play audio to: Built-in Output. Channel: 2. Sample rate: 44100. Sample Format: 8
2018-10-27 17:36:04: Preparing to record audio from: Built-in Microph. Channel: 2. Sample rate: 44100. Sample Format: 8
2018-10-27 17:36:16: RLMedia: Using AVStream.codec to pass codec parameters to muxers is deprecated, use AVStream.codecpar instead.
2018-10-27 17:36:16: Audio Decode Stats: Process 26.000000, Wait 0.000000
2018-10-27 17:36:16: Audio Encoding Stats: Process 6.000000, Wait 21.000000
2018-10-27 17:36:28: Preparing to play audio to: Built-in Output. Channel: 2. Sample rate: 44100. Sample Format: 8
2018-10-27 17:37:18: RLMedia: Using AVStream.codec to pass codec parameters to muxers is deprecated, use AVStream.codecpar instead.
2018-10-27 17:37:18: Preparing to play audio to: Built-in Output. Channel: 2. Sample rate: 44100. Sample Format: 8
2018-10-27 17:37:18: Preparing to record audio from: Built-in Microph. Channel: 2. Sample rate: 44100. Sample Format: 8
2018-10-27 17:37:36: RLMedia: Using AVStream.codec to pass codec parameters to muxers is deprecated, use AVStream.codecpar instead.
2018-10-27 17:37:36: Audio Decode Stats: Process 35.000000, Wait 0.000000
2018-10-27 17:37:36: Audio Encoding Stats: Process 21.000000, Wait 17.000000
2018-10-27 17:37:46: RLMedia: Using AVStream.codec to pass codec parameters to muxers is deprecated, use AVStream.codecpar instead.
2018-10-27 17:37:46: Preparing to play audio to: Built-in Output. Channel: 2. Sample rate: 44100. Sample Format: 8
2018-10-27 17:37:46: Preparing to record audio from: Built-in Microph. Channel: 2. Sample rate: 44100. Sample Format: 8
2018-10-27 17:37:49: RLMedia: Using AVStream.codec to pass codec parameters to muxers is deprecated, use AVStream.codecpar instead.
2018-10-27 17:37:49: Audio Decode Stats: Process 2.000000, Wait 0.000000
2018-10-27 17:37:49: Audio Encoding Stats: Process 0.000000, Wait 2.000000
2018-10-27 17:38:32: RLMedia: Using AVStream.codec to pass codec parameters to muxers is deprecated, use AVStream.codecpar instead.
2018-10-27 17:38:32: Preparing to play audio to: Built-in Output. Channel: 2. Sample rate: 44100. Sample Format: 8
2018-10-27 17:38:32: Preparing to record audio from: Built-in Microph. Channel: 2. Sample rate: 44100. Sample Format: 8
2018-10-27 17:38:51: Error: Cannot get the official hostname (error 0: Undefined error: 0)
2018-10-27 17:38:51: ActivePresenter 7.3.3 (Release Build: 2018.09.06) started
CPU Count: 4
Hostname: . Memory: 16,382 MB. Available: 5,844 MB
Disk Space: 239,172 MB (Free: 9,237 MB)
2018-10-27 17:38:51: TempDir: /Users/imcovangent/Library/Application Support/ActivePresenter/temp
2018-10-27 17:39:24: RLMedia: Using AVStream.codec to pass codec parameters to muxers is deprecated, use AVStream.codecpar instead.
2018-10-27 17:39:24: Preparing to play audio to: Built-in Output. Channel: 2. Sample rate: 44100. Sample Format: 8
2018-10-27 17:39:24: Preparing to record audio from: Built-in Microph. Channel: 2. Sample rate: 44100. Sample Format: 8
2018-10-27 17:39:38: RLMedia: Using AVStream.codec to pass codec parameters to muxers is deprecated, use AVStream.codecpar instead.
2018-10-27 17:39:38: Audio Decode Stats: Process 28.000000, Wait 0.000000
2018-10-27 17:39:38: Audio Encoding Stats: Process 9.000000, Wait 18.000000
2018-10-27 17:39:45: RLMedia: Using AVStream.codec to pass codec parameters to muxers is deprecated, use AVStream.codecpar instead.
2018-10-27 17:39:45: Preparing to play audio to: Built-in Output. Channel: 2. Sample rate: 44100. Sample Format: 8
2018-10-27 17:39:45: Preparing to record audio from: Built-in Microph. Channel: 2. Sample rate: 44100. Sample Format: 8
2018-10-27 17:40:04: RLMedia: Using AVStream.codec to pass codec parameters to muxers is deprecated, use AVStream.codecpar instead.
2018-10-27 17:40:04: Audio Decode Stats: Process 33.000000, Wait 0.000000
2018-10-27 17:40:04: Audio Encoding Stats: Process 14.000000, Wait 23.000000
2018-10-27 17:40:07: Preparing to play audio to: Built-in Output. Channel: 2. Sample rate: 44100. Sample Format: 8
2018-10-27 17:40:30: Preparing to play audio to: Built-in Output. Channel: 2. Sample rate: 44100. Sample Format: 8
2018-10-27 17:40:36: Preparing to play audio to: Built-in Output. Channel: 2. Sample rate: 44100. Sample Format: 8
2018-10-27 17:40:46: Preparing to play audio to: Built-in Output. Channel: 2. Sample rate: 44100. Sample Format: 8
2018-10-27 17:41:16: Error: Cannot get the official hostname (error 0: Undefined error: 0)
2018-10-27 17:41:16: ActivePresenter 7.3.3 (Release Build: 2018.09.06) started
CPU Count: 4
Hostname: . Memory: 16,383 MB. Available: 5,304 MB
Disk Space: 239,172 MB (Free: 8,942 MB)
2018-10-27 17:41:16: TempDir: /Users/imcovangent/Library/Application Support/ActivePresenter/temp
2018-10-27 17:42:05: RLMedia: Using AVStream.codec to pass codec parameters to muxers is deprecated, use AVStream.codecpar instead.
2018-10-27 17:42:05: Preparing to play audio to: Built-in Output. Channel: 2. Sample rate: 44100. Sample Format: 8
2018-10-27 17:42:05: Preparing to record audio from: Built-in Microph. Channel: 2. Sample rate: 44100. Sample Format: 8
2018-10-27 17:42:26: RLMedia: Using AVStream.codec to pass codec parameters to muxers is deprecated, use AVStream.codecpar instead.
2018-10-27 17:42:26: Audio Decode Stats: Process 58.000000, Wait 0.000000
2018-10-27 17:42:26: Audio Encoding Stats: Process 26.000000, Wait 35.000000
2018-10-27 17:42:35: Preparing to play audio to: Built-in Output. Channel: 2. Sample rate: 44100. Sample Format: 8
2018-10-27 17:42:53: RLMedia: Using AVStream.codec to pass codec parameters to muxers is deprecated, use AVStream.codecpar instead.
2018-10-27 17:42:53: Preparing to play audio to: Built-in Output. Channel: 2. Sample rate: 44100. Sample Format: 8
2018-10-27 17:42:53: Preparing to record audio from: Built-in Microph. Channel: 2. Sample rate: 44100. Sample Format: 8
2018-10-27 17:43:02: RLMedia: Using AVStream.codec to pass codec parameters to muxers is deprecated, use AVStream.codecpar instead.
2018-10-27 17:43:02: Audio Decode Stats: Process 22.000000, Wait 0.000000
2018-10-27 17:43:02: Audio Encoding Stats: Process 8.000000, Wait 13.000000
2018-10-27 17:43:05: Preparing to play audio to: Built-in Output. Channel: 2. Sample rate: 44100. Sample Format: 8
2018-10-27 17:43:32: Error: Cannot get the official hostname (error 0: Undefined error: 0)
2018-10-27 17:43:32: ActivePresenter 7.3.3 (Release Build: 2018.09.06) started
CPU Count: 4
Hostname: . Memory: 16,382 MB. Available: 5,130 MB
Disk Space: 239,172 MB (Free: 8,707 MB)
2018-10-27 17:43:32: TempDir: /Users/imcovangent/Library/Application Support/ActivePresenter/temp
2018-10-27 17:43:51: RLMedia: Using AVStream.codec to pass codec parameters to muxers is deprecated, use AVStream.codecpar instead.
2018-10-27 17:43:51: Audio Decode Stats: Process 52.000000, Wait 0.000000
2018-10-27 17:43:51: Audio Encoding Stats: Process 24.000000, Wait 30.000000
2018-10-27 17:44:08: RLMedia: Using AVStream.codec to pass codec parameters to muxers is deprecated, use AVStream.codecpar instead.
2018-10-27 17:44:08: Preparing to play audio to: Built-in Output. Channel: 2. Sample rate: 44100. Sample Format: 8
2018-10-27 17:44:08: Preparing to record audio from: Built-in Microph. Channel: 2. Sample rate: 44100. Sample Format: 8
2018-10-27 17:44:17: RLMedia: Using AVStream.codec to pass codec parameters to muxers is deprecated, use AVStream.codecpar instead.
2018-10-27 17:44:17: Audio Decode Stats: Process 20.000000, Wait 0.000000
2018-10-27 17:44:17: Audio Encoding Stats: Process 6.000000, Wait 15.000000
2018-10-27 17:44:22: Preparing to play audio to: Built-in Output. Channel: 2. Sample rate: 44100. Sample Format: 8
2018-10-27 17:44:30: Error: Cannot get the official hostname (error 0: Undefined error: 0)
2018-10-27 17:44:30: ActivePresenter 7.3.3 (Release Build: 2018.09.06) started
CPU Count: 4
Hostname: . Memory: 16,382 MB. Available: 5,054 MB
Disk Space: 239,172 MB (Free: 8,504 MB)
2018-10-27 17:44:30: TempDir: /Users/imcovangent/Library/Application Support/ActivePresenter/temp
2018-10-27 17:50:47: ActivePresenter 7.3.3 (Release Build: 2018.09.06) shut down
2018-10-27 17:57:55: Error: Cannot get the official hostname (error 0: Undefined error: 0)
2018-10-27 17:57:55: ActivePresenter 7.3.3 (Release Build: 2018.09.06) started
CPU Count: 4
Hostname: . Memory: 16,383 MB. Available: 8,514 MB
Disk Space: 239,172 MB (Free: 13,185 MB)
2018-10-27 17:57:55: TempDir: /Users/imcovangent/Library/Application Support/ActivePresenter/temp
2018-10-27 18:00:15: ActivePresenter 7.3.3 (Release Build: 2018.09.06) shut down
2018-10-27 18:52:46: Error: Cannot get the official hostname (error 0: Undefined error: 0)
2018-10-27 18:52:46: ActivePresenter 7.3.3 (Release Build: 2018.09.06) started
OS: OS X Version 10.14 (Build 18A391). Version: 10.14 - 64 bit
CPU Count: 4
Hostname: . Memory: 16,382 MB. Available: 8,943 MB
Disk Space: 239,172 MB (Free: 20,392 MB)
2018-10-27 18:52:46: TempDir: /Users/imcovangent/Library/Application Support/ActivePresenter/temp
2018-10-27 18:53:25: ActivePresenter 7.3.3 (Release Build: 2018.09.06) shut down
2018-10-27 18:53:29: Error: Cannot get the official hostname (error 0: Undefined error: 0)
2018-10-27 18:53:29: ActivePresenter 7.3.3 (Release Build: 2018.09.06) started
CPU Count: 4
Hostname: . Memory: 16,382 MB. Available: 7,464 MB
Disk Space: 239,172 MB (Free: 20,379 MB)
2018-10-27 18:53:29: TempDir: /Users/imcovangent/Library/Application Support/ActivePresenter/temp
2018-10-27 18:53:50: RLMedia: Using AVStream.codec to pass codec parameters to muxers is deprecated, use AVStream.codecpar instead.
2018-10-27 18:53:50: Audio Decode Stats: Process 55.000000, Wait 0.000000
2018-10-27 18:53:50: Audio Encoding Stats: Process 17.000000, Wait 47.000000
2018-10-27 18:53:50: Audio Decode Stats: Process 19.000000, Wait 0.000000
2018-10-27 18:53:50: Audio Encoding Stats: Process 7.000000, Wait 13.000000
2018-10-27 18:53:51: Preparing to play audio to: Built-in Output. Channel: 2. Sample rate: 44100. Sample Format: 8
2018-10-27 18:54:39: RLMedia: Using AVStream.codec to pass codec parameters to muxers is deprecated, use AVStream.codecpar instead.
2018-10-27 18:54:39: Preparing to play audio to: Built-in Output. Channel: 2. Sample rate: 44100. Sample Format: 8
2018-10-27 18:54:39: Preparing to record audio from: Built-in Microph. Channel: 2. Sample rate: 44100. Sample Format: 8
2018-10-27 18:54:46: RLMedia: Using AVStream.codec to pass codec parameters to muxers is deprecated, use AVStream.codecpar instead.
2018-10-27 18:54:46: Audio Decode Stats: Process 14.000000, Wait 0.000000
2018-10-27 18:54:46: Audio Encoding Stats: Process 4.000000, Wait 9.000000
2018-10-27 18:54:56: RLMedia: Using AVStream.codec to pass codec parameters to muxers is deprecated, use AVStream.codecpar instead.
2018-10-27 18:54:56: Preparing to play audio to: Built-in Output. Channel: 2. Sample rate: 44100. Sample Format: 8
2018-10-27 18:54:56: Preparing to record audio from: Built-in Microph. Channel: 2. Sample rate: 44100. Sample Format: 8
2018-10-27 18:55:03: RLMedia: Using AVStream.codec to pass codec parameters to muxers is deprecated, use AVStream.codecpar instead.
2018-10-27 18:55:03: Audio Decode Stats: Process 14.000000, Wait 0.000000
2018-10-27 18:55:03: Audio Encoding Stats: Process 7.000000, Wait 9.000000
2018-10-27 18:55:14: RLMedia: Using AVStream.codec to pass codec parameters to muxers is deprecated, use AVStream.codecpar instead.
2018-10-27 18:55:14: Preparing to play audio to: Built-in Output. Channel: 2. Sample rate: 44100. Sample Format: 8
2018-10-27 18:55:14: Preparing to record audio from: Built-in Microph. Channel: 2. Sample rate: 44100. Sample Format: 8
2018-10-27 18:55:33: RLMedia: Using AVStream.codec to pass codec parameters to muxers is deprecated, use AVStream.codecpar instead.
2018-10-27 18:55:33: Audio Decode Stats: Process 42.000000, Wait 0.000000
2018-10-27 18:55:33: Audio Encoding Stats: Process 13.000000, Wait 33.000000
2018-10-27 18:55:42: Preparing to play audio to: Built-in Output. Channel: 2. Sample rate: 44100. Sample Format: 8
2018-10-27 18:56:29: RLMedia: Using AVStream.codec to pass codec parameters to muxers is deprecated, use AVStream.codecpar instead.
2018-10-27 18:56:29: Preparing to play audio to: Built-in Output. Channel: 2. Sample rate: 44100. Sample Format: 8
2018-10-27 18:56:29: Preparing to record audio from: Built-in Microph. Channel: 2. Sample rate: 44100. Sample Format: 8
2018-10-27 18:56:39: Error: Cannot get the official hostname (error 0: Undefined error: 0)
2018-10-27 18:56:39: ActivePresenter 7.3.3 (Release Build: 2018.09.06) started
CPU Count: 4
Hostname: . Memory: 16,383 MB. Available: 6,418 MB
Disk Space: 239,172 MB (Free: 19,958 MB)
2018-10-27 18:56:39: TempDir: /Users/imcovangent/Library/Application Support/ActivePresenter/temp
2018-10-27 18:57:06: RLMedia: Using AVStream.codec to pass codec parameters to muxers is deprecated, use AVStream.codecpar instead.
2018-10-27 18:57:06: Audio Decode Stats: Process 40.000000, Wait 0.000000
2018-10-27 18:57:06: Audio Encoding Stats: Process 18.000000, Wait 22.000000
2018-10-27 18:57:11: Preparing to play audio to: Built-in Output. Channel: 2. Sample rate: 44100. Sample Format: 8
2018-10-27 18:57:45: RLMedia: Using AVStream.codec to pass codec parameters to muxers is deprecated, use AVStream.codecpar instead.
2018-10-27 18:57:45: Preparing to play audio to: Built-in Output. Channel: 2. Sample rate: 44100. Sample Format: 8
2018-10-27 18:57:45: Preparing to record audio from: Built-in Microph. Channel: 2. Sample rate: 44100. Sample Format: 8
2018-10-27 18:57:56: RLMedia: Using AVStream.codec to pass codec parameters to muxers is deprecated, use AVStream.codecpar instead.
2018-10-27 18:57:56: Audio Decode Stats: Process 28.000000, Wait 0.000000
2018-10-27 18:57:56: Audio Encoding Stats: Process 14.000000, Wait 15.000000
2018-10-27 18:58:04: Preparing to play audio to: Built-in Output. Channel: 2. Sample rate: 44100. Sample Format: 8
2018-10-27 18:59:10: RLMedia: Using AVStream.codec to pass codec parameters to muxers is deprecated, use AVStream.codecpar instead.
2018-10-27 18:59:10: Preparing to play audio to: Built-in Output. Channel: 2. Sample rate: 44100. Sample Format: 8
2018-10-27 18:59:10: Preparing to record audio from: Built-in Microph. Channel: 2. Sample rate: 44100. Sample Format: 8
2018-10-27 18:59:12: RLMedia: Using AVStream.codec to pass codec parameters to muxers is deprecated, use AVStream.codecpar instead.
2018-10-27 18:59:12: Audio Decode Stats: Process 1.000000, Wait 0.000000
2018-10-27 18:59:12: Audio Encoding Stats: Process 0.000000, Wait 2.000000
2018-10-27 18:59:20: RLMedia: Using AVStream.codec to pass codec parameters to muxers is deprecated, use AVStream.codecpar instead.
2018-10-27 18:59:20: Preparing to play audio to: Built-in Output. Channel: 2. Sample rate: 44100. Sample Format: 8
2018-10-27 18:59:20: Preparing to record audio from: Built-in Microph. Channel: 2. Sample rate: 44100. Sample Format: 8
2018-10-27 18:59:43: RLMedia: Using AVStream.codec to pass codec parameters to muxers is deprecated, use AVStream.codecpar instead.
2018-10-27 18:59:43: Audio Decode Stats: Process 56.000000, Wait 0.000000
2018-10-27 18:59:43: Audio Encoding Stats: Process 13.000000, Wait 45.000000
2018-10-27 18:59:46: Preparing to play audio to: Built-in Output. Channel: 2. Sample rate: 44100. Sample Format: 8
2018-10-27 19:01:01: Preparing to play audio to: Built-in Output. Channel: 2. Sample rate: 44100. Sample Format: 8
2018-10-27 19:01:12: Error: Cannot get the official hostname (error 0: Undefined error: 0)
2018-10-27 19:01:12: ActivePresenter 7.3.3 (Release Build: 2018.09.06) started
CPU Count: 4
Hostname: . Memory: 16,383 MB. Available: 5,837 MB
Disk Space: 239,172 MB (Free: 19,515 MB)
2018-10-27 19:01:12: TempDir: /Users/imcovangent/Library/Application Support/ActivePresenter/temp
2018-10-27 19:01:45: Preparing to play audio to: Built-in Output. Channel: 2. Sample rate: 44100. Sample Format: 8
2018-10-27 19:01:56: RLMedia: Using AVStream.codec to pass codec parameters to muxers is deprecated, use AVStream.codecpar instead.
2018-10-27 19:01:56: Preparing to play audio to: Built-in Output. Channel: 2. Sample rate: 44100. Sample Format: 8
2018-10-27 19:01:56: Preparing to record audio from: Built-in Microph. Channel: 2. Sample rate: 44100. Sample Format: 8
2018-10-27 19:02:13: RLMedia: Using AVStream.codec to pass codec parameters to muxers is deprecated, use AVStream.codecpar instead.
2018-10-27 19:02:14: Audio Decode Stats: Process 36.000000, Wait 0.000000
2018-10-27 19:02:14: Audio Encoding Stats: Process 14.000000, Wait 22.000000
2018-10-27 19:02:33: Preparing to play audio to: Built-in Output. Channel: 2. Sample rate: 44100. Sample Format: 8
2018-10-27 19:03:03: RLMedia: Using AVStream.codec to pass codec parameters to muxers is deprecated, use AVStream.codecpar instead.
2018-10-27 19:03:03: Preparing to play audio to: Built-in Output. Channel: 2. Sample rate: 44100. Sample Format: 8
2018-10-27 19:03:03: Preparing to record audio from: Built-in Microph. Channel: 2. Sample rate: 44100. Sample Format: 8
2018-10-27 19:03:20: Error: Cannot get the official hostname (error 0: Undefined error: 0)
2018-10-27 19:03:20: ActivePresenter 7.3.3 (Release Build: 2018.09.06) started
CPU Count: 4
Hostname: . Memory: 16,383 MB. Available: 5,872 MB
Disk Space: 239,172 MB (Free: 19,300 MB)
2018-10-27 19:03:20: TempDir: /Users/imcovangent/Library/Application Support/ActivePresenter/temp
2018-10-27 19:11:53: ActivePresenter 7.3.3 (Release Build: 2018.09.06) shut down
2018-10-27 19:16:26: Error: Cannot get the official hostname (error 0: Undefined error: 0)
2018-10-27 19:16:26: ActivePresenter 7.3.3 (Release Build: 2018.09.06) started
CPU Count: 4
Hostname: . Memory: 16,383 MB. Available: 5,297 MB
Disk Space: 239,172 MB (Free: 19,154 MB)
2018-10-27 19:16:26: TempDir: /Users/imcovangent/Library/Application Support/ActivePresenter/temp
2018-10-27 19:18:34: ActivePresenter 7.3.3 (Release Build: 2018.09.06) shut down
2018-10-27 19:18:36: Error: Cannot get the official hostname (error 0: Undefined error: 0)
2018-10-27 19:18:36: ActivePresenter 7.3.3 (Release Build: 2018.09.06) started
CPU Count: 4
Hostname: . Memory: 16,383 MB. Available: 4,721 MB
Disk Space: 239,172 MB (Free: 19,267 MB)
2018-10-27 19:18:36: TempDir: /Users/imcovangent/Library/Application Support/ActivePresenter/temp
2018-10-27 19:20:42: ActivePresenter 7.3.3 (Release Build: 2018.09.06) shut down
2018-10-27 19:20:52: Error: Cannot get the official hostname (error 0: Undefined error: 0)
2018-10-27 19:20:52: ActivePresenter 7.3.3 (Release Build: 2018.09.06) started
CPU Count: 4
Hostname: . Memory: 16,383 MB. Available: 5,031 MB
Disk Space: 239,172 MB (Free: 19,263 MB)
2018-10-27 19:20:52: TempDir: /Users/imcovangent/Library/Application Support/ActivePresenter/temp
2018-10-27 19:21:11: RLMedia: Using AVStream.codec to pass codec parameters to muxers is deprecated, use AVStream.codecpar instead.
2018-10-27 19:21:11: Preparing to play audio to: Built-in Output. Channel: 2. Sample rate: 44100. Sample Format: 8
2018-10-27 19:21:11: Preparing to record audio from: Built-in Microph. Channel: 2. Sample rate: 44100. Sample Format: 8
2018-10-27 19:21:36: Error: Cannot get the official hostname (error 0: Undefined error: 0)
2018-10-27 19:21:36: ActivePresenter 7.3.3 (Release Build: 2018.09.06) started
CPU Count: 4
Hostname: . Memory: 16,382 MB. Available: 4,816 MB
Disk Space: 239,172 MB (Free: 19,056 MB)
2018-10-27 19:21:36: TempDir: /Users/imcovangent/Library/Application Support/ActivePresenter/temp
2018-10-27 19:30:02: ActivePresenter 7.3.3 (Release Build: 2018.09.06) shut down
2018-10-27 19:30:05: Error: Cannot get the official hostname (error 0: Undefined error: 0)
2018-10-27 19:30:05: ActivePresenter 7.3.3 (Release Build: 2018.09.06) started
CPU Count: 4
Hostname: . Memory: 16,383 MB. Available: 4,150 MB
Disk Space: 239,172 MB (Free: 19,255 MB)
2018-10-27 19:30:05: TempDir: /Users/imcovangent/Library/Application Support/ActivePresenter/temp
