ActivePresenter 9.0.1 stops recording every now and then
ActivePresenter version:
Version 9.0.1 - 64-bit build. (Released: 2022.10.06)
OS:
Window 10
I’m using the program for about 2 years how and never faced this problem. I’m recording screen as a video for about 3 minutes as an example. When I press CTRL-End after 3 minutes only a minute or 2 is recorded. I got no warning that the recording was ended for some reason.
Greetings,
Albert
Please deselect the Use Direct3D for recording screen checkbox and try recording again (click the Gear icon on the Record Screen as a Video Project dialog > Recording Settings… > Audio & Video tab > Video Settings section).
Also, please share the log of ActivePresenter to help us analyze the issue further.
To view the log, click ActivePresenter button > Preferences > Miscellaneous > View Log.
You can refer to this video to see the detailed steps: How to Find and Send ActivePresenter's Log File - ActivePresenter 8 - YouTube
Warm regards,
Hello Thuy,
Thanks for the reply. I changed the setting as you mentioned.
I will record a video with the new setting and let you know if this solved the problem.
Unfortunately I cannot upload the log file yet since I’m a new user.
Have a nice day.
Albert.
Hi Albert,
Yes, please try recording again.
Besides, you can send the log of ActivePresenter to our email address support@atomisystems.com.
BR,
