My Rodecaster Pro (fw 2.1) works fine in all other applications.
2021-03-18 08:41:23: Probing audio device for recording. Error: Invalid device. Retrying with default parameters
2021-03-18 08:41:23: RLMedia: Using AVStream.codec to pass codec parameters to muxers is deprecated, use AVStream.codecpar instead.
2021-03-18 08:41:23: Preparing to record audio from: Microphone (RODECaster Pro Multichannel). Channel: 14. Sample rate: 48000. Sample Format: 8
2021-03-18 08:41:23: RLMedia: Input channel count and layout are unset
2021-03-18 08:41:23: RLAudioRecorderPrivate: Could not init audio resampler
2021-03-18 08:41:44: RLMedia: Using AVStream.codec to pass codec parameters to muxers is deprecated, use AVStream.codecpar instead.
2021-03-18 08:41:44: Preparing to record audio from: Microphone (Live Streamer CAM 513). Channel: 2. Sample rate: 44100. Sample Format: 2147483656
2021-03-18 08:41:44: Failed to open audio stream to record. Error: Invalid number of channels.
2021-03-18 08:41:44: Preparing to record audio from: Microphone (Live Streamer CAM 513). Channel: 1. Sample rate: 44100. Sample Format: 8
2021-03-18 08:41:49: RLMedia: Using AVStream.codec to pass codec parameters to muxers is deprecated, use AVStream.codecpar instead.
2021-03-18 08:41:49: Preparing to record audio from: Microphone (Live Streamer CAM 513). Channel: 1. Sample rate: 44100. Sample Format: 8
2021-03-18 08:41:54: Preparing to play audio to: Speakers (RODECaster Pro Stereo). Channel: 2. Sample rate: 48000. Sample Format: 8
2021-03-18 08:41:54: Audio frames decoding started.
2021-03-18 08:42:06: Probing audio device for recording. Error: Invalid device. Retrying with default parameters
2021-03-18 08:42:33: Probing audio device for recording. Error: Invalid device. Retrying with default parameters
2021-03-18 08:42:33: RLMedia: Using AVStream.codec to pass codec parameters to muxers is deprecated, use AVStream.codecpar instead.
2021-03-18 08:42:33: Preparing to record audio from: Microphone (RODECaster Pro Multichannel). Channel: 14. Sample rate: 48000. Sample Format: 8
2021-03-18 08:42:33: RLMedia: Input channel count and layout are unset
2021-03-18 08:42:33: RLAudioRecorderPrivate: Could not init audio resampler
2021-03-18 08:43:49: Probing audio device for recording. Error: Invalid device. Retrying with default parameters
2021-03-18 08:43:49: RLMedia: Using AVStream.codec to pass codec parameters to muxers is deprecated, use AVStream.codecpar instead.
2021-03-18 08:43:49: Preparing to record audio from: Microphone (RODECaster Pro Multichannel). Channel: 14. Sample rate: 48000. Sample Format: 8
2021-03-18 08:43:49: RLMedia: Input channel count and layout are unset
2021-03-18 08:43:49: RLAudioRecorderPrivate: Could not init audio resampler
2021-03-18 08:45:21: Probing audio device for recording. Error: Invalid device. Retrying with default parameters
ActivePresenter version: Version 8.3.2 - 64-bit build. (Released: 2021.01.26)
OS: Win 10 Pro
