Please find below the part of the log file.
First part is the session when the last error happened… it happened at 15:27.
The second part is the restart of activepresenter
2020-05-04 14:38:13: ActivePresenter 8.0.6 (Release Build: 2020.04.28) started
OS: Windows 10 (build 18363), 64-bit edition. Version: 10.0 - 64 bit
CPU Count: 8
Hostname: Guy-Desktop. Memory: 32,705 MB. Available: 29,219 MB. Memory Load: 10%
Project Location: C:\Users\Guy\Documents\ActivePresenter
Disk Space: 487,385 MB (Free: 146,213 MB)
2020-05-04 14:38:14: TempDir: C:\Users\Guy\AppData\Roaming\ActivePresenter\temp
2020-05-04 14:38:14: Last renderers: 1
2020-05-04 14:38:14: Direct3D rendering mode: software
2020-05-04 14:38:14: Direct3D device type: 5
2020-05-04 14:38:15: Error while adding device to list: Windows WASAPI:Speakers (Realtek High Definition Audio): Invalid device
2020-05-04 14:38:31: Opening project: D:\Dropbox (Personal)\Education\Cours\2TPCM\Coinf3\2019-2020\Videos eLearning\COINF3 Chapitre 1.approj
2020-05-04 14:38:36: PrepareRibbonBar: 639ms
2020-05-04 14:38:49: RLMedia: Using AVStream.codec to pass codec parameters to muxers is deprecated, use AVStream.codecpar instead.
2020-05-04 14:38:49: Audio Decoding Stats: Process 82.000000, Wait 0.000000
2020-05-04 14:38:49: Audio Encoding Stats: Process 37.000000, Wait 70.000000
2020-05-04 14:38:49: Audio Decoding Stats: Process 17.000000, Wait 0.000000
2020-05-04 14:38:49: Audio Encoding Stats: Process 9.000000, Wait 14.000000
2020-05-04 14:38:49: Audio Decoding Stats: Process 54.000000, Wait 0.000000
2020-05-04 14:38:49: Audio Encoding Stats: Process 29.000000, Wait 31.000000
2020-05-04 14:38:49: Audio Decoding Stats: Process 11.000000, Wait 3.000000
2020-05-04 14:38:49: Audio Encoding Stats: Process 12.000000, Wait 3.000000
2020-05-04 14:38:50: Audio Decoding Stats: Process 38.000000, Wait 4.000000
2020-05-04 14:38:50: Audio Encoding Stats: Process 20.000000, Wait 31.000000
2020-05-04 14:38:50: RLMedia: Using AVStream.codec to pass codec parameters to muxers is deprecated, use AVStream.codecpar instead.
2020-05-04 14:38:50: Audio Decoding Stats: Process 34.000000, Wait 0.000000
2020-05-04 14:38:50: Audio Encoding Stats: Process 15.000000, Wait 22.000000
2020-05-04 14:38:50: Audio Decoding Stats: Process 76.000000, Wait 4.000000
2020-05-04 14:38:50: Audio Encoding Stats: Process 28.000000, Wait 48.000000
2020-05-04 14:38:50: Audio Decoding Stats: Process 6.000000, Wait 71.000000
2020-05-04 14:38:50: Audio Encoding Stats: Process 77.000000, Wait 1.000000
2020-05-04 14:38:51: Render Project Size: 1920 x 1080
2020-05-04 14:38:51: Threads Used: 4 / 8, Memory Available: 25,324/32,705
2020-05-04 14:38:51: Preparing to play audio to: Lautsprecher (Jabra Link 370). Channel: 2. Sample rate: 48000. Sample Format: 8
2020-05-04 14:38:51: Audio Decoding Stats: Process 39.000000, Wait 54.000000
2020-05-04 14:38:51: Audio Encoding Stats: Process 76.000000, Wait 26.000000
2020-05-04 14:38:51: RLMedia: Using AVStream.codec to pass codec parameters to muxers is deprecated, use AVStream.codecpar instead.
2020-05-04 14:38:51: Video frames decoding started.
2020-05-04 14:38:51: Audio frames decoding started.
2020-05-04 14:38:51: Audio Decoding Stats: Process 128.000000, Wait 3.000000
2020-05-04 14:38:51: Audio Encoding Stats: Process 50.000000, Wait 126.000000
2020-05-04 14:38:53: RLMedia: Using AVStream.codec to pass codec parameters to muxers is deprecated, use AVStream.codecpar instead.
2020-05-04 14:38:53: Audio Decoding Stats: Process 55.000000, Wait 3.000000
2020-05-04 14:38:53: Audio Encoding Stats: Process 26.000000, Wait 33.000000
2020-05-04 14:38:53: Audio Decoding Stats: Process 23.000000, Wait 0.000000
2020-05-04 14:38:53: Audio Encoding Stats: Process 6.000000, Wait 49.000000
2020-05-04 14:38:56: RLMedia: Using AVStream.codec to pass codec parameters to muxers is deprecated, use AVStream.codecpar instead.
2020-05-04 14:38:57: Audio Decoding Stats: Process 38.000000, Wait 3.000000
2020-05-04 14:38:57: Audio Encoding Stats: Process 15.000000, Wait 23.000000
2020-05-04 14:38:57: RLMedia: Using AVStream.codec to pass codec parameters to muxers is deprecated, use AVStream.codecpar instead.
2020-05-04 14:38:57: Audio Decoding Stats: Process 72.000000, Wait 10.000000
2020-05-04 14:38:57: Audio Encoding Stats: Process 40.000000, Wait 38.000000
2020-05-04 14:38:57: Audio Decoding Stats: Process 55.000000, Wait 3.000000
2020-05-04 14:38:57: Audio Encoding Stats: Process 24.000000, Wait 48.000000
2020-05-04 14:38:57: Audio Decoding Stats: Process 36.000000, Wait 0.000000
2020-05-04 14:38:57: Audio Encoding Stats: Process 16.000000, Wait 59.000000
2020-05-04 14:38:57: Audio Decoding Stats: Process 8.000000, Wait 199.000000
2020-05-04 14:38:57: Audio Encoding Stats: Process 1.000000, Wait 0.000000
2020-05-04 14:39:29: c587e833-4186-44ee-b9de-1adbeb1f195c: Seek after: 31.000000
2020-05-04 14:41:26: Render Project Size: 1920 x 1080
2020-05-04 14:41:26: Threads Used: 4 / 8, Memory Available: 24,079/32,705
2020-05-04 14:41:26: Preparing to play audio to: Lautsprecher (Jabra Link 370). Channel: 2. Sample rate: 48000. Sample Format: 8
2020-05-04 14:41:26: Video frames decoding started.
2020-05-04 14:41:26: Audio frames decoding started.
2020-05-04 14:41:26: c587e833-4186-44ee-b9de-1adbeb1f195c: Seek after: 34.000000
2020-05-04 14:41:53: Render Project Size: 1920 x 1080
2020-05-04 14:41:53: Threads Used: 4 / 8, Memory Available: 23,905/32,705
2020-05-04 14:41:53: Preparing to play audio to: Lautsprecher (Jabra Link 370). Channel: 2. Sample rate: 48000. Sample Format: 8
2020-05-04 14:41:53: Audio frames decoding started.
2020-05-04 14:41:53: Video frames decoding started.
2020-05-04 14:41:53: c587e833-4186-44ee-b9de-1adbeb1f195c: Seek after: 30.000000
2020-05-04 14:42:17: RLMedia: No streams to mux were specified
2020-05-04 14:42:37: Render Project Size: 1920 x 1080
2020-05-04 14:42:37: Threads Used: 4 / 8, Memory Available: 24,054/32,705
2020-05-04 14:42:37: Preparing to play audio to: Lautsprecher (Jabra Link 370). Channel: 2. Sample rate: 48000. Sample Format: 8
2020-05-04 14:42:37: Video frames decoding started.
2020-05-04 14:42:37: Audio frames decoding started.
2020-05-04 14:42:37: c587e833-4186-44ee-b9de-1adbeb1f195c: Seek after: 13.000000
2020-05-04 14:42:47: Render Project Size: 1920 x 1080
2020-05-04 14:42:47: Threads Used: 4 / 8, Memory Available: 23,944/32,705
2020-05-04 14:42:47: Preparing to play audio to: Lautsprecher (Jabra Link 370). Channel: 2. Sample rate: 48000. Sample Format: 8
2020-05-04 14:42:47: Video frames decoding started.
2020-05-04 14:42:47: Audio frames decoding started.
2020-05-04 14:42:47: c587e833-4186-44ee-b9de-1adbeb1f195c: Seek after: 20.000000
2020-05-04 14:43:01: Render Project Size: 1920 x 1080
2020-05-04 14:43:01: Threads Used: 4 / 8, Memory Available: 23,751/32,705
2020-05-04 14:43:01: Preparing to play audio to: Lautsprecher (Jabra Link 370). Channel: 2. Sample rate: 48000. Sample Format: 8
2020-05-04 14:43:01: Video frames decoding started.
2020-05-04 14:43:01: Audio frames decoding started.
2020-05-04 14:43:01: c587e833-4186-44ee-b9de-1adbeb1f195c: Seek after: 12.000000
2020-05-04 14:43:30: Render Project Size: 1920 x 1080
2020-05-04 14:43:30: Threads Used: 4 / 8, Memory Available: 22,763/32,705
2020-05-04 14:43:30: Preparing to play audio to: Lautsprecher (Jabra Link 370). Channel: 2. Sample rate: 48000. Sample Format: 8
2020-05-04 14:43:30: Video frames decoding started.
2020-05-04 14:43:30: Audio frames decoding started.
2020-05-04 14:43:30: c587e833-4186-44ee-b9de-1adbeb1f195c: Seek after: 13.000000
2020-05-04 14:44:01: Render Project Size: 1920 x 1080
2020-05-04 14:44:01: Threads Used: 4 / 8, Memory Available: 23,674/32,705
2020-05-04 14:44:01: Preparing to play audio to: Lautsprecher (Jabra Link 370). Channel: 2. Sample rate: 48000. Sample Format: 8
2020-05-04 14:44:01: Audio frames decoding started.
2020-05-04 14:44:01: Video frames decoding started.
2020-05-04 14:44:01: c587e833-4186-44ee-b9de-1adbeb1f195c: Seek after: 19.000000
2020-05-04 14:44:54: Render Project Size: 1920 x 1080
2020-05-04 14:44:54: Threads Used: 4 / 8, Memory Available: 23,723/32,705
2020-05-04 14:44:54: Preparing to play audio to: Lautsprecher (Jabra Link 370). Channel: 2. Sample rate: 48000. Sample Format: 8
2020-05-04 14:44:54: Video frames decoding started.
2020-05-04 14:44:54: Audio frames decoding started.
2020-05-04 14:44:54: c587e833-4186-44ee-b9de-1adbeb1f195c: Seek after: 31.000000
2020-05-04 14:45:55: Render Project Size: 1920 x 1080
2020-05-04 14:45:55: Threads Used: 4 / 8, Memory Available: 23,731/32,705
2020-05-04 14:45:55: Preparing to play audio to: Lautsprecher (Jabra Link 370). Channel: 2. Sample rate: 48000. Sample Format: 8
2020-05-04 14:45:55: Video frames decoding started.
2020-05-04 14:45:55: Audio frames decoding started.
2020-05-04 14:45:55: c587e833-4186-44ee-b9de-1adbeb1f195c: Seek after: 13.000000
2020-05-04 14:46:16: Render Project Size: 1920 x 1080
2020-05-04 14:46:16: Threads Used: 4 / 8, Memory Available: 23,642/32,705
2020-05-04 14:46:16: Preparing to play audio to: Lautsprecher (Jabra Link 370). Channel: 2. Sample rate: 48000. Sample Format: 8
2020-05-04 14:46:16: Audio frames decoding started.
2020-05-04 14:46:16: Video frames decoding started.
2020-05-04 14:46:17: c587e833-4186-44ee-b9de-1adbeb1f195c: Seek after: 12.000000
2020-05-04 14:46:25: Render Project Size: 1920 x 1080
2020-05-04 14:46:25: Threads Used: 4 / 8, Memory Available: 23,581/32,705
2020-05-04 14:46:25: Preparing to play audio to: Lautsprecher (Jabra Link 370). Channel: 2. Sample rate: 48000. Sample Format: 8
2020-05-04 14:46:25: Audio frames decoding started.
2020-05-04 14:46:25: Video frames decoding started.
2020-05-04 14:46:25: c587e833-4186-44ee-b9de-1adbeb1f195c: Seek after: 13.000000
2020-05-04 14:59:23: Render Project Size: 1920 x 1080
2020-05-04 14:59:23: Threads Used: 4 / 8, Memory Available: 23,093/32,705
2020-05-04 14:59:23: Preparing to play audio to: Lautsprecher (Jabra Link 370). Channel: 2. Sample rate: 48000. Sample Format: 8
2020-05-04 14:59:23: Audio frames decoding started.
2020-05-04 14:59:23: Video frames decoding started.
2020-05-04 14:59:24: c587e833-4186-44ee-b9de-1adbeb1f195c: Seek after: 13.000000
2020-05-04 14:59:52: Render Project Size: 1920 x 1080
2020-05-04 14:59:52: Threads Used: 4 / 8, Memory Available: 22,957/32,705
2020-05-04 14:59:52: Preparing to play audio to: Lautsprecher (Jabra Link 370). Channel: 2. Sample rate: 48000. Sample Format: 8
2020-05-04 14:59:52: Video frames decoding started.
2020-05-04 14:59:52: Audio frames decoding started.
2020-05-04 14:59:52: c587e833-4186-44ee-b9de-1adbeb1f195c: Seek after: 30.000000
2020-05-04 14:59:58: Render Project Size: 1920 x 1080
2020-05-04 14:59:58: Threads Used: 4 / 8, Memory Available: 22,824/32,705
2020-05-04 14:59:58: Preparing to play audio to: Lautsprecher (Jabra Link 370). Channel: 2. Sample rate: 48000. Sample Format: 8
2020-05-04 14:59:59: Video frames decoding started.
2020-05-04 14:59:59: Audio frames decoding started.
2020-05-04 14:59:59: c587e833-4186-44ee-b9de-1adbeb1f195c: Seek after: 41.000000
2020-05-04 15:00:19: Render Project Size: 1920 x 1080
2020-05-04 15:00:19: Threads Used: 4 / 8, Memory Available: 22,901/32,705
2020-05-04 15:00:19: Preparing to play audio to: Lautsprecher (Jabra Link 370). Channel: 2. Sample rate: 48000. Sample Format: 8
2020-05-04 15:00:20: Audio frames decoding started.
2020-05-04 15:00:20: Video frames decoding started.
2020-05-04 15:00:20: c587e833-4186-44ee-b9de-1adbeb1f195c: Seek after: 13.000000
2020-05-04 15:01:50: RLMedia: Using AVStream.codec to pass codec parameters to muxers is deprecated, use AVStream.codecpar instead.
2020-05-04 15:01:50: Preparing to record audio from: Microphone (RODE NT-USB). Channel: 2. Sample rate: 48000. Sample Format: 8
2020-05-04 15:02:02: RLMedia: Using AVStream.codec to pass codec parameters to muxers is deprecated, use AVStream.codecpar instead.
2020-05-04 15:02:02: Audio Decoding Stats: Process 18.000000, Wait 0.000000
2020-05-04 15:02:02: Audio Encoding Stats: Process 10.000000, Wait 13.000000
2020-05-04 15:02:20: Render Project Size: 1920 x 1080
2020-05-04 15:02:20: Threads Used: 4 / 8, Memory Available: 22,905/32,705
2020-05-04 15:02:20: Preparing to play audio to: Lautsprecher (Jabra Link 370). Channel: 2. Sample rate: 48000. Sample Format: 8
2020-05-04 15:02:20: Audio frames decoding started.
2020-05-04 15:02:20: Video frames decoding started.
2020-05-04 15:02:21: c587e833-4186-44ee-b9de-1adbeb1f195c: Seek after: 25.000000
2020-05-04 15:02:36: Render Project Size: 1920 x 1080
2020-05-04 15:02:36: Threads Used: 4 / 8, Memory Available: 22,846/32,705
2020-05-04 15:02:36: Preparing to play audio to: Lautsprecher (Jabra Link 370). Channel: 2. Sample rate: 48000. Sample Format: 8
2020-05-04 15:02:36: Audio frames decoding started.
2020-05-04 15:02:36: Video frames decoding started.
2020-05-04 15:02:37: c587e833-4186-44ee-b9de-1adbeb1f195c: Seek after: 24.000000
2020-05-04 15:03:16: Render Project Size: 1920 x 1080
2020-05-04 15:03:16: Threads Used: 4 / 8, Memory Available: 22,845/32,705
2020-05-04 15:03:16: Preparing to play audio to: Lautsprecher (Jabra Link 370). Channel: 2. Sample rate: 48000. Sample Format: 8
2020-05-04 15:03:16: Audio frames decoding started.
2020-05-04 15:03:16: Video frames decoding started.
2020-05-04 15:03:16: c587e833-4186-44ee-b9de-1adbeb1f195c: Seek after: 30.000000
2020-05-04 15:04:29: Render Project Size: 1920 x 1080
2020-05-04 15:04:29: Threads Used: 4 / 8, Memory Available: 22,886/32,705
2020-05-04 15:04:29: Preparing to play audio to: Lautsprecher (Jabra Link 370). Channel: 2. Sample rate: 48000. Sample Format: 8
2020-05-04 15:04:29: Video frames decoding started.
2020-05-04 15:04:29: Audio frames decoding started.
2020-05-04 15:04:29: c587e833-4186-44ee-b9de-1adbeb1f195c: Seek after: 44.000000
2020-05-04 15:04:54: Render Project Size: 1920 x 1080
2020-05-04 15:04:54: Threads Used: 4 / 8, Memory Available: 22,752/32,705
2020-05-04 15:04:54: Preparing to play audio to: Lautsprecher (Jabra Link 370). Channel: 2. Sample rate: 48000. Sample Format: 8
2020-05-04 15:04:54: Audio frames decoding started.
2020-05-04 15:04:54: Video frames decoding started.
2020-05-04 15:04:54: c587e833-4186-44ee-b9de-1adbeb1f195c: Seek after: 25.000000
2020-05-04 15:05:16: Render Project Size: 1920 x 1080
2020-05-04 15:05:16: Threads Used: 4 / 8, Memory Available: 22,722/32,705
2020-05-04 15:05:16: Preparing to play audio to: Lautsprecher (Jabra Link 370). Channel: 2. Sample rate: 48000. Sample Format: 8
2020-05-04 15:05:16: Audio frames decoding started.
2020-05-04 15:05:16: Video frames decoding started.
2020-05-04 15:05:17: c587e833-4186-44ee-b9de-1adbeb1f195c: Seek after: 24.000000
2020-05-04 15:05:37: Render Project Size: 1920 x 1080
2020-05-04 15:05:37: Threads Used: 4 / 8, Memory Available: 22,666/32,705
2020-05-04 15:05:37: Preparing to play audio to: Lautsprecher (Jabra Link 370). Channel: 2. Sample rate: 48000. Sample Format: 8
2020-05-04 15:05:37: Audio frames decoding started.
2020-05-04 15:05:37: Video frames decoding started.
2020-05-04 15:05:37: c587e833-4186-44ee-b9de-1adbeb1f195c: Seek after: 19.000000
2020-05-04 15:06:12: Render Project Size: 1920 x 1080
2020-05-04 15:06:12: Threads Used: 4 / 8, Memory Available: 22,763/32,705
2020-05-04 15:06:12: Preparing to play audio to: Lautsprecher (Jabra Link 370). Channel: 2. Sample rate: 48000. Sample Format: 8
2020-05-04 15:06:12: Audio frames decoding started.
2020-05-04 15:06:12: Video frames decoding started.
2020-05-04 15:06:13: c587e833-4186-44ee-b9de-1adbeb1f195c: Seek after: 23.000000
2020-05-04 15:06:33: Render Project Size: 1920 x 1080
2020-05-04 15:06:33: Threads Used: 4 / 8, Memory Available: 22,606/32,705
2020-05-04 15:06:33: Preparing to play audio to: Lautsprecher (Jabra Link 370). Channel: 2. Sample rate: 48000. Sample Format: 8
2020-05-04 15:06:33: Audio frames decoding started.
2020-05-04 15:06:33: Video frames decoding started.
2020-05-04 15:06:33: c587e833-4186-44ee-b9de-1adbeb1f195c: Seek after: 25.000000
2020-05-04 15:07:01: Render Project Size: 1920 x 1080
2020-05-04 15:07:01: Threads Used: 4 / 8, Memory Available: 22,661/32,705
2020-05-04 15:07:01: Preparing to play audio to: Lautsprecher (Jabra Link 370). Channel: 2. Sample rate: 48000. Sample Format: 8
2020-05-04 15:07:01: Audio frames decoding started.
2020-05-04 15:07:01: Video frames decoding started.
2020-05-04 15:07:02: c587e833-4186-44ee-b9de-1adbeb1f195c: Seek after: 26.000000
2020-05-04 15:07:18: Render Project Size: 1920 x 1080
2020-05-04 15:07:18: Threads Used: 4 / 8, Memory Available: 22,640/32,705
2020-05-04 15:07:18: Preparing to play audio to: Lautsprecher (Jabra Link 370). Channel: 2. Sample rate: 48000. Sample Format: 8
2020-05-04 15:07:18: Audio frames decoding started.
2020-05-04 15:07:18: Video frames decoding started.
2020-05-04 15:07:18: c587e833-4186-44ee-b9de-1adbeb1f195c: Seek after: 38.000000
2020-05-04 15:07:44: Render Project Size: 1920 x 1080
2020-05-04 15:07:44: Threads Used: 4 / 8, Memory Available: 22,723/32,705
2020-05-04 15:07:44: Preparing to play audio to: Lautsprecher (Jabra Link 370). Channel: 2. Sample rate: 48000. Sample Format: 8
2020-05-04 15:07:44: Audio frames decoding started.
2020-05-04 15:07:44: Video frames decoding started.
2020-05-04 15:07:44: c587e833-4186-44ee-b9de-1adbeb1f195c: Seek after: 31.000000
2020-05-04 15:07:52: Render Project Size: 1920 x 1080
2020-05-04 15:07:52: Threads Used: 4 / 8, Memory Available: 22,644/32,705
2020-05-04 15:07:52: Preparing to play audio to: Lautsprecher (Jabra Link 370). Channel: 2. Sample rate: 48000. Sample Format: 8
2020-05-04 15:07:52: Audio frames decoding started.
2020-05-04 15:07:52: Video frames decoding started.
2020-05-04 15:07:52: c587e833-4186-44ee-b9de-1adbeb1f195c: Seek after: 32.000000
2020-05-04 15:08:08: Render Project Size: 1920 x 1080
2020-05-04 15:08:08: Threads Used: 4 / 8, Memory Available: 22,677/32,705
2020-05-04 15:08:08: Preparing to play audio to: Lautsprecher (Jabra Link 370). Channel: 2. Sample rate: 48000. Sample Format: 8
2020-05-04 15:08:08: Audio frames decoding started.
2020-05-04 15:08:08: Video frames decoding started.
2020-05-04 15:08:09: c587e833-4186-44ee-b9de-1adbeb1f195c: Seek after: 8.000000
2020-05-04 15:08:32: Render Project Size: 1920 x 1080
2020-05-04 15:08:32: Threads Used: 4 / 8, Memory Available: 22,537/32,705
2020-05-04 15:08:32: Preparing to play audio to: Lautsprecher (Jabra Link 370). Channel: 2. Sample rate: 48000. Sample Format: 8
2020-05-04 15:08:32: Video frames decoding started.
2020-05-04 15:08:32: Audio frames decoding started.
2020-05-04 15:08:32: c587e833-4186-44ee-b9de-1adbeb1f195c: Seek after: 8.000000
2020-05-04 15:08:50: Render Project Size: 1920 x 1080
2020-05-04 15:08:50: Threads Used: 4 / 8, Memory Available: 22,560/32,705
2020-05-04 15:08:50: Preparing to play audio to: Lautsprecher (Jabra Link 370). Channel: 2. Sample rate: 48000. Sample Format: 8
2020-05-04 15:08:50: Audio frames decoding started.
2020-05-04 15:08:50: Video frames decoding started.
2020-05-04 15:08:50: c587e833-4186-44ee-b9de-1adbeb1f195c: Seek after: 12.000000
2020-05-04 15:09:00: Render Project Size: 1920 x 1080
2020-05-04 15:09:00: Threads Used: 4 / 8, Memory Available: 22,559/32,705
2020-05-04 15:09:00: Preparing to play audio to: Lautsprecher (Jabra Link 370). Channel: 2. Sample rate: 48000. Sample Format: 8
2020-05-04 15:09:00: Audio frames decoding started.
2020-05-04 15:09:00: Video frames decoding started.
2020-05-04 15:09:00: c587e833-4186-44ee-b9de-1adbeb1f195c: Seek after: 11.000000
2020-05-04 15:09:20: Render Project Size: 1920 x 1080
2020-05-04 15:09:20: Threads Used: 4 / 8, Memory Available: 22,475/32,705
2020-05-04 15:09:20: Preparing to play audio to: Lautsprecher (Jabra Link 370). Channel: 2. Sample rate: 48000. Sample Format: 8
2020-05-04 15:09:20: Audio frames decoding started.
2020-05-04 15:09:20: Video frames decoding started.
2020-05-04 15:09:20: c587e833-4186-44ee-b9de-1adbeb1f195c: Seek after: 24.000000
2020-05-04 15:09:30: Render Project Size: 1920 x 1080
2020-05-04 15:09:30: Threads Used: 4 / 8, Memory Available: 22,456/32,705
2020-05-04 15:09:30: Preparing to play audio to: Lautsprecher (Jabra Link 370). Channel: 2. Sample rate: 48000. Sample Format: 8
2020-05-04 15:09:30: Audio frames decoding started.
2020-05-04 15:09:30: Video frames decoding started.
2020-05-04 15:09:30: c587e833-4186-44ee-b9de-1adbeb1f195c: Seek after: 41.000000
2020-05-04 15:09:43: Render Project Size: 1920 x 1080
2020-05-04 15:09:43: Threads Used: 4 / 8, Memory Available: 22,394/32,705
2020-05-04 15:09:43: Preparing to play audio to: Lautsprecher (Jabra Link 370). Channel: 2. Sample rate: 48000. Sample Format: 8
2020-05-04 15:09:43: Audio frames decoding started.
2020-05-04 15:09:43: Video frames decoding started.
2020-05-04 15:09:43: c587e833-4186-44ee-b9de-1adbeb1f195c: Seek after: 24.000000
2020-05-04 15:10:04: Render Project Size: 1920 x 1080
2020-05-04 15:10:04: Threads Used: 4 / 8, Memory Available: 22,517/32,705
2020-05-04 15:10:04: Preparing to play audio to: Lautsprecher (Jabra Link 370). Channel: 2. Sample rate: 48000. Sample Format: 8
2020-05-04 15:10:04: Audio frames decoding started.
2020-05-04 15:10:04: Video frames decoding started.
2020-05-04 15:10:04: c587e833-4186-44ee-b9de-1adbeb1f195c: Seek after: 13.000000
2020-05-04 15:10:20: Render Project Size: 1920 x 1080
2020-05-04 15:10:20: Threads Used: 4 / 8, Memory Available: 22,344/32,705
2020-05-04 15:10:20: Preparing to play audio to: Lautsprecher (Jabra Link 370). Channel: 2. Sample rate: 48000. Sample Format: 8
2020-05-04 15:10:20: Audio frames decoding started.
2020-05-04 15:10:20: Video frames decoding started.
2020-05-04 15:10:20: c587e833-4186-44ee-b9de-1adbeb1f195c: Seek after: 14.000000
2020-05-04 15:11:00: Render Project Size: 1920 x 1080
2020-05-04 15:11:00: Threads Used: 4 / 8, Memory Available: 22,478/32,705
2020-05-04 15:11:00: Preparing to play audio to: Lautsprecher (Jabra Link 370). Channel: 2. Sample rate: 48000. Sample Format: 8
2020-05-04 15:11:00: Audio frames decoding started.
2020-05-04 15:11:00: Video frames decoding started.
2020-05-04 15:11:00: c587e833-4186-44ee-b9de-1adbeb1f195c: Seek after: 18.000000
2020-05-04 15:24:28: Render Project Size: 1920 x 1080
2020-05-04 15:24:28: Threads Used: 4 / 8, Memory Available: 22,176/32,705
2020-05-04 15:24:28: Preparing to play audio to: Lautsprecher (Jabra Link 370). Channel: 2. Sample rate: 48000. Sample Format: 8
2020-05-04 15:24:28: Audio frames decoding started.
2020-05-04 15:24:28: Video frames decoding started.
2020-05-04 15:24:29: c587e833-4186-44ee-b9de-1adbeb1f195c: Seek after: 32.000000
2020-05-04 15:24:37: Render Project Size: 1920 x 1080
2020-05-04 15:24:37: Threads Used: 4 / 8, Memory Available: 22,044/32,705
2020-05-04 15:24:37: Preparing to play audio to: Lautsprecher (Jabra Link 370). Channel: 2. Sample rate: 48000. Sample Format: 8
2020-05-04 15:24:37: Video frames decoding started.
2020-05-04 15:24:37: Audio frames decoding started.
2020-05-04 15:24:37: c587e833-4186-44ee-b9de-1adbeb1f195c: Seek after: 33.000000
2020-05-04 15:24:46: Render Project Size: 1920 x 1080
2020-05-04 15:24:46: Threads Used: 4 / 8, Memory Available: 21,943/32,705
2020-05-04 15:24:46: Preparing to play audio to: Lautsprecher (Jabra Link 370). Channel: 2. Sample rate: 48000. Sample Format: 8
2020-05-04 15:24:46: Video frames decoding started.
2020-05-04 15:24:46: Audio frames decoding started.
2020-05-04 15:24:46: c587e833-4186-44ee-b9de-1adbeb1f195c: Seek after: 34.000000
2020-05-04 15:24:57: Render Project Size: 1920 x 1080
2020-05-04 15:24:57: Threads Used: 4 / 8, Memory Available: 22,034/32,705
2020-05-04 15:24:57: Preparing to play audio to: Lautsprecher (Jabra Link 370). Channel: 2. Sample rate: 48000. Sample Format: 8
2020-05-04 15:24:57: Video frames decoding started.
2020-05-04 15:24:57: Audio frames decoding started.
2020-05-04 15:24:57: c587e833-4186-44ee-b9de-1adbeb1f195c: Seek after: 33.000000
2020-05-04 15:25:28: Render Project Size: 1920 x 1080
2020-05-04 15:25:28: Threads Used: 4 / 8, Memory Available: 22,065/32,705
2020-05-04 15:25:28: Preparing to play audio to: Lautsprecher (Jabra Link 370). Channel: 2. Sample rate: 48000. Sample Format: 8
2020-05-04 15:25:28: Audio frames decoding started.
2020-05-04 15:25:28: Video frames decoding started.
2020-05-04 15:25:28: c587e833-4186-44ee-b9de-1adbeb1f195c: Seek after: 32.000000
2020-05-04 15:25:45: Render Project Size: 1920 x 1080
2020-05-04 15:25:45: Threads Used: 4 / 8, Memory Available: 22,027/32,705
2020-05-04 15:25:45: Preparing to play audio to: Lautsprecher (Jabra Link 370). Channel: 2. Sample rate: 48000. Sample Format: 8
2020-05-04 15:25:45: Audio frames decoding started.
2020-05-04 15:25:45: Video frames decoding started.
2020-05-04 15:25:45: c587e833-4186-44ee-b9de-1adbeb1f195c: Seek after: 35.000000
2020-05-04 15:26:14: Render Project Size: 1920 x 1080
2020-05-04 15:26:14: Threads Used: 4 / 8, Memory Available: 22,053/32,705
2020-05-04 15:26:14: Preparing to play audio to: Lautsprecher (Jabra Link 370). Channel: 2. Sample rate: 48000. Sample Format: 8
2020-05-04 15:26:14: Video frames decoding started.
2020-05-04 15:26:14: Audio frames decoding started.
2020-05-04 15:26:14: c587e833-4186-44ee-b9de-1adbeb1f195c: Seek after: 23.000000
2020-05-04 15:26:40: Render Project Size: 1920 x 1080
2020-05-04 15:26:40: Threads Used: 4 / 8, Memory Available: 21,947/32,705
2020-05-04 15:26:40: Preparing to play audio to: Lautsprecher (Jabra Link 370). Channel: 2. Sample rate: 48000. Sample Format: 8
2020-05-04 15:26:40: Audio frames decoding started.
2020-05-04 15:26:40: Video frames decoding started.
2020-05-04 15:26:40: c587e833-4186-44ee-b9de-1adbeb1f195c: Seek after: 24.000000
2020-05-04 15:26:49: Render Project Size: 1920 x 1080
2020-05-04 15:26:49: Threads Used: 4 / 8, Memory Available: 21,824/32,705
2020-05-04 15:26:49: Preparing to play audio to: Lautsprecher (Jabra Link 370). Channel: 2. Sample rate: 48000. Sample Format: 8
2020-05-04 15:26:50: Audio frames decoding started.
2020-05-04 15:26:50: Video frames decoding started.
2020-05-04 15:26:50: c587e833-4186-44ee-b9de-1adbeb1f195c: Seek after: 30.000000
2020-05-04 15:27:09: Render Project Size: 1920 x 1080
2020-05-04 15:27:09: Threads Used: 4 / 8, Memory Available: 21,906/32,705
2020-05-04 15:27:09: Preparing to play audio to: Lautsprecher (Jabra Link 370). Channel: 2. Sample rate: 48000. Sample Format: 8
2020-05-04 15:27:09: Video frames decoding started.
2020-05-04 15:27:09: Audio frames decoding started.
2020-05-04 15:27:09: c587e833-4186-44ee-b9de-1adbeb1f195c: Seek after: 28.000000
2020-05-04 15:27:24: Render Project Size: 1920 x 1080
2020-05-04 15:27:24: Threads Used: 4 / 8, Memory Available: 21,791/32,705
2020-05-04 15:27:24: Preparing to play audio to: Lautsprecher (Jabra Link 370). Channel: 2. Sample rate: 48000. Sample Format: 8
2020-05-04 15:27:24: Video frames decoding started.
2020-05-04 15:27:24: Audio frames decoding started.
2020-05-04 15:27:24: c587e833-4186-44ee-b9de-1adbeb1f195c: Seek after: 26.000000
2020-05-04 15:27:37: Render Project Size: 1920 x 1080
2020-05-04 15:27:37: Threads Used: 4 / 8, Memory Available: 21,887/32,705
2020-05-04 15:27:37: Preparing to play audio to: Lautsprecher (Jabra Link 370). Channel: 2. Sample rate: 48000. Sample Format: 8
2020-05-04 15:27:38: Audio frames decoding started.
2020-05-04 15:27:38: Video frames decoding started.
2020-05-04 15:27:38: c587e833-4186-44ee-b9de-1adbeb1f195c: Seek after: 35.000000
2020-05-04 15:28:26: ActivePresenter 8.0.6 (Release Build: 2020.04.28) started
CPU Count: 8
Hostname: Guy-Desktop. Memory: 32,705 MB. Available: 22,541 MB. Memory Load: 31%
Disk Space: 487,385 MB (Free: 141,763 MB)
2020-05-04 15:28:26: TempDir: C:\Users\Guy\AppData\Roaming\ActivePresenter\temp
2020-05-04 15:28:26: Direct3D rendering mode: software
2020-05-04 15:28:26: Direct3D device type: 5
2020-05-04 15:28:27: Error while adding device to list: Windows WASAPI:Speakers (Realtek High Definition Audio): Invalid device
