i saved my recording. Then I checked the folder. There was the video and the audio file. After I renamed the folder, the audio file was missing. Is it possible to restore the audio file ?
Please help me
You should rename the folder back to its original name.
That folder is not meant to be touched manually by user.
Best Regards,
Thanks, but how do i know which was the original name?
Hi Peter,
The folder should has the name in the form projectFileName_files
For example, if your project file is myProject.approj
, the folder will be myProject_files
