Hey guys can active presenter project be exported to PowerPoint with all interactions like drag and drops, quiescent and so on
Hi Ruslan,
Could you kindly let me know your purpose of exporting to PowerPoint?
For your information, after exported to PowerPoint, all of the objects (including placeholders) and their properties remain unchanged and you can edit them as normal.
However, all the interactions and effects will be removed.
You cannot edit objects inserted using Slide Master, either.
In other words, any object inserted into Slide Master will be flattened and merged into the background image of the PowerPoint slide.
Please find more details about exporting projects to Microsoft PowerPoint via the link below:
Warm regards,
Quynh Anh
