Problem: After successfully activating ActivePresenter 8.3.0, it says it can’t be stored locally, even after turning of my firewall.
ActivePresenter version: 8.3.0
OS: OSX Big Sur
OS: OSX Big Sur
Please set the permission of the /Users/Shared folder as in the screenshot below to see if it helps:
thank you for the tip. However, my folder settings were already like you indicated, and still the activation can’t be stored.
best, Willem
Can you please try the following steps:
If you get a volume limit error while activating, you can reset the license at ActivePresenter License Activation Management
This worked! Thank you very much,
Willem
