I have a tutorial with audio narration. Since on Chrome, it starts mute, on the player there the suggestion to click or tap to unmute.
I also added a button to start the tutorial that at the same time were unmuting the audio (because it nedds a click or a tap). With version 7, this were working, but now, on version 8 doesn’t.
How can I activate the audio with 1 click or a tap only?
There’s a bug in version 8 that causes this issue in some cases.
We’ll release a fix soon.
In the meantime, you can add an action to the button On Click event to unmute the audio explicitly:
I am experiencing the same issue, where we added an audio toggle to set the variable to true, if audio is wanted by user. On true, the audio will play on load.
However, if the audio toggle is not activated and the user clicks the “Start Now” button to begin, then the volume button is automatically active, due to the click action, but obviously no audio will play because the variable is not true.
How can we edit the toolbar, in order to show everything not active, in case the variable is stilll false.
