I was trying to use the ‘On ended’ action, to sync the end of the audio with a move to the next page, but I can’t make it work.
Any help is appreciated.
Hi Koen,
It is a known issue in ActivePresenter 8.5.6.
Can you please add a small gap (1-2 second is enough) to the audio as in the image below:
This duration helps the audio have enough time to complete playing before disappearing.
We will fix the problem in the future update.
Thanks so much for the quick reply.
Really appreciate it!
