I have a multiple monitor setup. I think ActivePresenter uses the monitor you are running ActivePresenter in to determine which screen it will capture when a full screen simulation is recorded. It would be nice to be able to select which monitor is recorded like you can with the Lock to Application feature. Maybe a call it a Lock to Monitor feature?
Hi Jim,
Thanks for sharing the idea.
We’ll consider adding this feature if there are more requests from others.
Kind regards,
Hi Jim,
The workaround is moving the Recording dialog to the monitor that you want to record, then select the Full screen button.
