How to connect 2 drag sources with one Drag Target. It was doable in version 6 by changing the Drag Sourses & Tragets in the Quaestion properties. I will appreacite support.
Paulina
Hi Paulina,
There are two ways to do this:
- Connect Drag Source to Drop Target by mouse:
- Make sure that the View > Drag-n-Drop option is selected.
- On Canvas, select the Drag Source.
- Click the circle at the center of the Drag Source, hold the mouse.
- Drag the mouse to the center of the Drop Target and release.
- Using Properties pane.
- Select the Drop Target.
- In the Properties pane, select the Interactivity tab.
- Expand the Drag-n-Drop section.
- Click the button next to Accept List.
- Check the Correct column.
Thank you. I used the 2nd option and it worked.
